Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
i wouldn't worry about loctite on the stud. if it's a non blind hole, add thread pucky and double nut and screw in. clamping force will be attained by the studnut.
Studs are not "torqued. Studs should be screwed into the block until just finger tight and the nuts should be torqued to 50-55 lb-ft.
Bolts are screwed into the block and torqued to 65-70 lb-ft.
Studs are 7/16 diameter and 3 inchs long i believe one side is 7/16-14 and the other 7/16 - 20 ( going by memory.. it's been a while since i pulled a head.. but that seems to be what i remember )
14 is coarse and goes into the block.
8n6065a is the bolt number from NH.... NH no longer has the studs.... napa will generically carry studs that fit the measurements i gave you.
