Ford 9N lift arms
   / Ford 9N lift arms #1
jrd1990zr1
Ford 1320
I have an older Ford 9N which had a PTO driven buzz saw table attached. The flat belt saw had no guards so I removed it. I noticed the 3 point lift arms will not lift. Any advice on where to start to fix this? I have limited repair information (manuals) on how the system works and before I start taking this apart thought I would see if anyone else has had this problem.
Thanks
   / Ford 9N lift arms #2
The 9n hydraulics run off of the PTO, make sure it is engaged.
   / Ford 9N lift arms #3
Lift cylinder is on the bottom side of the top cover that the seat is mounted to. Not too bad of a job to service if needed. Pick up a manual, they are plentiful and inexpensive for such a popular tractor.
   / Ford 9N lift arms #4
Check fluid level and condition, clean, dirty?
It has the absolutely craziest pump I have ever seen.
If you have the common repair manual it should have troubleshooting info.
   / Ford 9N lift arms
I've got to ask this, sorry if it sounds like a dumb question. So when the PTO output shaft is engaged and spinning that is when the 3 point lift harms will only work?
Very different from my Ford 1320
   / Ford 9N lift arms #6
Yes, the 1320 has live hydraulics (when the engine is running you have hydraulics), the 9N does not, One of the many advances through the years to make tractor work easier.
   / Ford 9N lift arms
OK, My bad. The 3 point lift arms work fine with the PTO engaged. seems a bit dangerous with the flat belt pulley spinning. Guess I should remove it. Thanks for the advice.
   / Ford 9N lift arms #8
Yes, hydraulic pump is a scotch yoke type that the pro shaft runs through.
   / Ford 9N lift arms #9
If you can find it there is a cover that screws into the back of the differential case that covers the splined pto shaft when not being used. Might be able to find one on line.
   / Ford 9N lift arms #10
Guard Rail Pieces (A51692)
Guard Rail Pieces...
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
MONOSEM NG-3 LOT IDENTIFIER 232 (A53084)
MONOSEM NG-3 LOT...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
