Ford 9N Hydraulics
   / Ford 9N Hydraulics #1
Walk
McCall, ID
Ford 9N
I recently replaced the hydraulic lift control valve on my ford 9N tractor. I pushed the valve assembly into the hole in the pump below the pressure relief valve. It did not slide in easily. Now the lift raises slowly but stays in the up position. Any advice?
Should the control valve slides easily in and out? I sure appreciate any advice.
   / Ford 9N Hydraulics #2
Yes. It should slide easily. There should be no resistance.
Mike
   / Ford 9N Hydraulics #3
Take it back out. So.etching didn't go together right.
Not sure if the 9n is the same as an 8n, and not sure I remember right, but i think there is a small hole/slot that the lever has to fit into. If you were outside that, it may move one way, but not being "engaged" would cause it to not move the other way.
Thanks Mike will redo
   / Ford 9N Hydraulics #5
hopefully you cleaned it out and removed any grit / dirt too.
I honed out the port, the valve slides easily and the lift works great. Thanks to all of you who took the time to respond with your suggestions.
Walk
   / Ford 9N Hydraulics #7
Glad you got it fixed. Thanks for keeping us posted.
Mike
   / Ford 9N Hydraulics #8
cool, it did soud like it was hanging up!
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
19010 (A48082)
19010 (A48082)
2011 Cadillac SRX (A50324)
2011 Cadillac SRX...
