ford 9n hard start
   / ford 9n hard start #1
earndale
oswego new york
mf gc2300
rebuilt carburetor set float choke been set but when cold will not start unless i spray starting fluid in it first and hold choke on and off till warmed up ??
   / ford 9n hard start #3
Start at the beginning, make sure all 3 of the screens in the fuel system are clean. Remove to plug from the bottom of the carb and be sure you have a full flow through it. Also pull a plug wire to be sure you have a BRIGHT BLUE spark and not a weak yellow spark.
It really sounds like you have a weak spark problem.
72in Large Capacity Bucket (A49251)
72in Large...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A46683)
2006 GMC C8500...
Farm Hand 825 Grinder Mixer (A49251)
Farm Hand 825...
Stoltzfus Hay Wagon (A49251)
Stoltzfus Hay...
Skid Steer Auger Drive & Bit Set (A47371)
Skid Steer Auger...
PENDING SELLER CONFIRMATIONS (A45679)
PENDING SELLER...
