Ford 951 brush hog parts
   / Ford 951 brush hog parts #1
butzkeg
SE Michigan
John Deere 4300 HST
Anyone know of a place online that I can order parts for a Ford brush hog? I had a brush hog given to me, but I need to repair/replace the gearbox on it. Any help would be appreciated.
   / Ford 951 brush hog parts #2
Some of Ford's rotary cutters are OEM'd by KingKutter..., but gearboxes are used by many mfrs... should be a label on your gearbox to id it... most popular is probably "OMNI"...
Get some names and numbers and what parts you think you need and I'll try to help with some pricing/diagrams/sources/etc... /w3tcompact/icons/smile.gif
Thanks, John. I found one of your past posts on the OMNI gearbox.
So, I went and checked out the OMNI website, and it sure looks to be the same product.
I looked at the gearbox yesterday (it's next door at my grandpa's), and 1 number on it was "5A19". There was a second number, much longer though, and didn't bring anything to write it down on.
The part I know is shot is #13 from the diagram<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=119702&page=&view=&sb=&o=&vc=1> omni parts breakdown </A>
I am wondering though, what else is missing. My grandpa took the box apart, and left it open, in the rain for about 1 year. It's a bit rusty on the inside, so I wonder if it would be worth fixing.
I'll get some more #'s off the gearbox and cutter this weekend.
John, thanks for being patient. Here are the numbers I could find:
brush hog series: 951
brush hog component: 22BM0203
brush hog serires: WM-24514
#'s from the gearbox itself:
"5A19" and "14727 1010 H"
   / Ford 951 brush hog parts #5
new holland part number BMB0711050100 suggested price $243.32 hope this helps. If you cant find one locally let me know I can ups you one to you.
Is that the entire gearbox?
   / Ford 951 brush hog parts #7
Re: Ford 951 brush hog parts-gearbox info
Hi Greg,
Well I'm told this unit was mfr. between '84-87, and the gearbox is by BMB... I had never heard of...
I don't know exactly what parts you need, but NH said the output gearshaft is about $240. by itself... but you can buy the entire gearbox complete with shipping for about $264.
The NH dealer on board seems to have an excellent price for $243. for the entire gearbox.
You may want to look at the OMNI 40 hp gearbox used on a number of rotary cutters... the price is about $150 complete... but I don't know if the output shaft spline is the same as your current one...
$150 sounds much better than $243, but $243 is still a lot less than a new 6ft. medium duty brush hog.
Would I just count the spline's on the shaft to see if it was the same?
   / Ford 951 brush hog parts #9
<font color=blue>...Would I just count the spline's on the shaft to see if it was the same? ...</font color=blue>
Well... that's some of it... but you also have to have the same diameter, and the same pitch... etc. etc.
The OMNI 40 HP gearbox is a "regular duty" unit... not medium duty... I believe the "peak" hp rating is 60 hp for the OMNI... so your JD4300 won't damage it... /w3tcompact/icons/blush.gif
Before you commit yourself, have your blade pan off (keep the blades attached) and you can see if the OMNI shaft will fit. If you plan on upgrading the tractor later, you may want to bite the bullet and just get the Ford gearbox and not fiddle around with anything...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2012 JOHN DEERE 520 SHREDDER LOT IDENTIFIER 237 (A53084)
2012 JOHN DEERE...
LMC G500-500A LOT IDENTIFIER 217 (A53084)
LMC G500-500A LOT...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Pair of New 700/40-225 Alliance Tires with Rims (A53472)
Pair of New...
