Ford 950 3pt hitch problems
/ Ford 950 3pt hitch problems #1
Kando
Cromwell, Indiana
2xFord 5000, Ford 960
Hello TBN,
Question I have is this: On our tractor, a Ford 950, the 3 pt hitch arms don't move with a full range of motion. The arms are only affected when the lift/drop lever (for lack of a better term) is in the top third/fourth of it's traverse. Top lifts the arms (although I don't believe they lift fully), move the lever down 2 inches and they drop completely. Any lower and there's no feedback. This tractor is mainly used for hay, so the 3pt doesn't come into play but if this problem can be fixed I'd like to do so.
Thanks, all help appreciated!
Kando
/ Ford 950 3pt hitch problems #2
It could be the mode the hydraulics are set in. There should be a small lever near the rock shaft behind the seat. 1 position is more for plowing, the other is more for work that requires holding a position. I can take a pic after I get home if needed.
I'll take a look at that shortly, pic would be appreciated, thanks!
/ Ford 950 3pt hitch problems #4
OK, I'll get a picture once it quits raining long enough to get out there.
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
2010 Dodge Charger Sedan (A66738)
2010 Dodge Charger...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2015 JLG G12-55A TELEHANDLER (A67714)
2015 JLG G12-55A...
kobota mx5400 for sale
