ford 8n what are the chances
   / ford 8n what are the chances #1
rjhans53
Mulberry, FL
Iseki 1910 Ford 8n B
I get and install a new starter last week, life seams like it's getting good. I changed the plugs out today, messed with the thing a bit and it wouldn't start after it had fire up about 20 times or so. WHAT the fug, so I figured the solenoid was bad and changed it, absolutely nothing, did a direct short to the starter post, NOTHING, a brand new starter going bad in less than a week, what are the chances,
   / ford 8n what are the chances #2
Could be a bad starter, but a double check ground connection(s) from engine to battery also.
I know it's a bad way to check but I popped the lead from the + to ground, got a really good spark so I think the ground is good
   / ford 8n what are the chances #4
is the starter stuck with drive gear engaged into flywheel?
Ok so I pulled the starter, hook it up to a battery, and it spins, for a time or 2. Bump it with the palm of my hand and it will spin for a time or 2. roll it over and it will spin, for a time or 2. Am I missing something that bad or??
   / ford 8n what are the chances #6
sounds like sticking brushes ... time to take it back and ask for a replacement ( or at least have them check it )
   / ford 8n what are the chances #7
bad brushes / problem or the armature is worn out.
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
199049 (A51243)
199049 (A51243)
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
