ford 8n what are the chances
   / ford 8n what are the chances #1
rjhans53
Bronze Member
Mulberry, FL
Iseki 1910 Ford 8n B
I get and install a new starter last week, life seams like it's getting good. I changed the plugs out today, messed with the thing a bit and it wouldn't start after it had fire up about 20 times or so. WHAT the fug, so I figured the solenoid was bad and changed it, absolutely nothing, did a direct short to the starter post, NOTHING, a brand new starter going bad in less than a week, what are the chances,
   / ford 8n what are the chances #2
Could be a bad starter, but a double check ground connection(s) from engine to battery also.
I know it's a bad way to check but I popped the lead from the + to ground, got a really good spark so I think the ground is good
   / ford 8n what are the chances #4
is the starter stuck with drive gear engaged into flywheel?
Ok so I pulled the starter, hook it up to a battery, and it spins, for a time or 2. Bump it with the palm of my hand and it will spin for a time or 2. roll it over and it will spin, for a time or 2. Am I missing something that bad or??
   / ford 8n what are the chances #6
sounds like sticking brushes ... time to take it back and ask for a replacement ( or at least have them check it )
   / ford 8n what are the chances #7
bad brushes / problem or the armature is worn out.
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
