ford 8n smokes
   / ford 8n smokes #1
jrichards
I have a 1952 Ford 8-n tractor with a positive ground. When ideling the tractor puffs white smoke, while under load the smoke goes away, why?
   / ford 8n smokes #2
'white' smoke generally is steam, and can mean a blown head gasket or worse.. like a cracked block or head.
is there water ( emulsion) in the oil.. or oily sheens in the radiator water?
since you posted she is hard to start cold, this is a good place to start with a compression test.. might have a blown head gasket and geeting leaks between 2 cyls.. making her start rough, blow steam .. etc.. look for steamcleaned spark plugs.
soundguy
soundguy
   / ford 8n smokes #3
White smoke can also be unburnt fuel.
Whats it smell like ?
   / ford 8n smokes #4
or half-burnt oil. My 8N smokes all the time, I say I am spraying for mosiqtoes.
   / ford 8n smokes
how do u fix the problem if these condensation in the fuel tank?
   / ford 8n smokes #8
keep the tank full.. less surface area and air volume for condensation.
and any water that does form usually makes it to the sediment bowl.. and should easilly be seen... bowl is made to be dumped to clean.
soundguy
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 JOHN DEERE 6140M LOT IDENTIFIER 246 (A53084)
2022 JOHN DEERE...
