ford 8n smokes
   / ford 8n smokes #1
jrichards
I have a 1952 Ford 8-n tractor with a positive ground. When ideling the tractor puffs white smoke, while under load the smoke goes away, why?
   / ford 8n smokes #2
'white' smoke generally is steam, and can mean a blown head gasket or worse.. like a cracked block or head.
is there water ( emulsion) in the oil.. or oily sheens in the radiator water?
since you posted she is hard to start cold, this is a good place to start with a compression test.. might have a blown head gasket and geeting leaks between 2 cyls.. making her start rough, blow steam .. etc.. look for steamcleaned spark plugs.
soundguy
soundguy
   / ford 8n smokes #3
White smoke can also be unburnt fuel.
Whats it smell like ?
   / ford 8n smokes #4
or half-burnt oil. My 8N smokes all the time, I say I am spraying for mosiqtoes.
   / ford 8n smokes
how do u fix the problem if these condensation in the fuel tank?
   / ford 8n smokes #8
keep the tank full.. less surface area and air volume for condensation.
and any water that does form usually makes it to the sediment bowl.. and should easilly be seen... bowl is made to be dumped to clean.
soundguy
2000 Sterling L9513 Winch Truck (A53472)
2000 Sterling...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
