Ford 8N sediment bowl Shut Off Valve
   / Ford 8N sediment bowl Shut Off Valve #1
carpediem4570
Edmonton, ab
MF65, Ford 8N, AC WF
I have a little Ford 8N. I was out discing a small patch for planting a garden. When I finished, I brought the tractor back to the house and went to shut the fuel off at the sediment bowl. Well, turns out the screw holding the turn handle to the bowl backed out and I lost the screw and the handle in the field. I am using a pair of pliers to turn the valve. Can anyone here tell me where I can get the little screw and circular handle that fits on the bowl?
Thanks in advance for your help.
Kind regards,
Carpediem
   / Ford 8N sediment bowl Shut Off Valve #2
Tractor Supply has a good many parts for an 8n. I got a new sediment bowl from them. Can't remember what else was in the box though.
   / Ford 8N sediment bowl Shut Off Valve #3
You will probably have to buy the whole assembly.
   / Ford 8N sediment bowl Shut Off Valve #4
   / Ford 8N sediment bowl Shut Off Valve #6
Looks like RickB found what you need.
Thanks folks for all the help. Will order my parts and put away the pliers.
Kind regards,
Carpediem
2006 TerraGator 8104 (A53472)
2006 TerraGator...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
Electric Concrete Mixer (A51573)
Electric Concrete...
DOOSAN DL300-3 HYD 4N1 COMBO BUCKET (A51247)
DOOSAN DL300-3 HYD...
