Ford 8n Radiator: replace or rebuild?
   / Ford 8n Radiator: replace or rebuild? #1
HUTCHAMUSPRIME
Ford 5000, 8n sidemount, 4500 backhoe
I was bush hogging and a stick found itd way through thr grill and into the radiator. (I only have the attached screenshot atm) Ive been reading around and I see there are some quality issues with new radiators. There is a shop that rebuilds radiators about 45 minutes away. I'm not even sure if this is original. I think both options results in the same amount of down time for me. What do y'all recommend?
   / Ford 8n Radiator: replace or rebuild? #2
Back when I had an 8N I had to replace the radiator and tried a couple of different ones but NONE fit properly until I stumbled upon a radiator made in Ireland. It was not perfect but WAY closer to a proper fit than anything else. SO if you have a shop that can rebuild your old one that is the route I would take.
   / Ford 8n Radiator: replace or rebuild? #3
X2 for rebuild.
Aluminum radiators (usually what you get anymore)
Don’t cool as well as copper.
Rebuild the old one :)
   / Ford 8n Radiator: replace or rebuild? #5
Another vote for rebuilding. One of the nice things about the N Fords is that many components were engineered to be rebuilt multiple times. When you reinstall it, get new bumpers and a new Brillo pad for the area between the radiator and hood, and you will be good to go for a long time.
Hate to disappoint but I ended up just going with one of those aluminum replacements someone gave me a good review about. The only fitment issue was the radiator cap. Bothers me more than it should. Its cooling great! I did keep the old one and I'm going to get it repaired if they can repair it! I am sure I'll end up with another stick in this one before too long. I never learn anything... I will have the old one ready to put back in!
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2014 Electric Cart (A53424)
2014 Electric Cart...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
