Ford 8n ignition switch
/ Ford 8n ignition switch #1
fibrostic
I am working through some starting issues on my 8N. It is a side mount, and i have put new points (set to .025), and a new condenser on it. I am now thinking maybe something is wrong with the ignition switch, the actual on off switch. Mine has what looks like an aftermarket toggle (push in / pull out ) switch instead of the key. Occasionally when i turn it on, the points don't spark at all, after switching it on and off a few times, it works again. I am trying to find a NAPA part number for something that will work. Doesn't have to be a factory replacement, but something that fit the hole and has the right set up would be nice. ideas?
/ Ford 8n ignition switch #2
I would just buy a universal key switch. You can get them @ NAPA, tsc, probabally autozone/advanced, etc. They usually arent more than $10
/ Ford 8n ignition switch #3
You just described a simple headlight switch for the igniton. A key switch would be better..
I agree, i am hoping someone knows or can find a part number, preferably from NAPA.
/ Ford 8n ignition switch #5
you dont need a part #, just ask them for a universal 2-wire kew switch.
They may even be able to look a specific one up if you tell them "key switch" for an "8n".
That is what they do. That is why they have a hundred books/computer system with cross references. Let them do the work on finding a part #. You jsut tell them what you need.:thumbsup:
/ Ford 8n ignition switch #6
Agreed, probably one of the most popular tractors to look for parts, the N series, by Ford. I saw the switches on a card in TSC on my last visit.
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2022 John Deere 5055E (A60462)
2022 John Deere...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
More info coming soon (A61569)
More info coming...
iDrive TDS-2010H...
2018 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2018 Ford F-150...
