Ford 8N dribbling coolant out of radiator overflow, not overfilled.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #61
Without a recovery system you'll always have air in the radiator due to thermodynamics. I would put a 2 liter bottle with the overflow tube submerged at the bottom, take a scotchbrite disc and clean up the top seal on the neck, and verify that the radiator cap has a rubber seal at the top and bottom, so when it cools down it has to draw fluid back in, rather than atmosphere. The bend in the filler neck shouldn't be an issue, unless there is a crack that would allow air back in.
Be sure the cap is correct for a recovery system:
Update: After borrowing a tester, I found no signs of compression in the cooling system. After having the radiator fill neck straightened, the problem went away. No more coolant dribbling out of the overflow.
I guess the neck was bent enough to hold the cap up and cause a bad seal.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #63
You prompted good conversation on cooling systems.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #64
Glad to hear it was a simple fix in the end with plenty of hoops jumped though to get there (y)
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #65
Admirable you were not deterred…
Thanks again for all the useful advice folks! 🍻
I definitely learned a lot about cooling systems these past few days- very useful knowledge to have.
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2008 Ford Ranger Pickup Truck (A55852)
2008 Ford Ranger...
2007 Walker Mudhog (A55787)
2007 Walker Mudhog...
2022 Third Coast Reversible Plate Compactor (A54865)
2022 Third Coast...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
