Ford 861 pull a 15' batwing mower?
   / Ford 861 pull a 15' batwing mower? #1
IC Smoke
PITTSFORD, MI
Kubota B2400, ZD28, BX24
Hey gang, I stumbled across a 15' woods batwing finish mower but wasnt sure if the Ford would be up for the challenge. Its a older batwing mower but on woods website they say the motor HP should be between 35-80 hp. Tractor data says the 861 is 62hp but I'm not sure what the PTO hp rating is.
I have about 7 acres to mow and my 7' flail just takes too long. I would like to have a 10-12' mower but the price is right on the 15' at the moment.
TractorData.com Ford Powermaster 861 tractor engine information
TBW180 Finish Mowers
Thanks
Ian
   / Ford 861 pull a 15' batwing mower? #2
Mid 40's PTO HP iirc.
HP is speed. I think it will pull it fine if you have a low enough gear an it isn't too thick. Think about small lawn mowers that used to have 12-14 HP and did fine with a 4' deck.
Now the same mowers come with 20+ HP. It allows faster ground speed.
And if the deal is a good one, if it don't work like you want, re-sell it.
   / Ford 861 pull a 15' batwing mower? #3
i gotta think that 15' mower ( unless it's a golf course finish job ) is gonna not play well with that 861 that likely has about 48 pto hp or so.
for one thing.. it's gonna be tugging on that drawbar hanger something awfull.
i might run an 8' dual spindle mower on a 861 if i had to....
i use a 5000 on a 10' mower.. I know our county has used 5610 on 15' mowers.
I have a neighbor that used to use a 5000 on a 15' mower. it was a later job like mine with 256ci engine.. etc.
that's my opinion anyway..
the weight on a 15' mower is quite a lot. i'd hate to feel that thing with wings folded..
i pull a 15' jd 1517 with a NH 7610s... a 95ish hp tractor. nice and heavy.. .. that weigth adds to safety.. and te drawbar carier is much beeffier.
again.. my opinion.
I sure wouldn't put my 4000 4 cyl ( equiv to an 801 ) on something like that.
ps i assume that the mower has the 540 6 spline pto, and not the 1000 rpm pto input..etc.
   / Ford 861 pull a 15' batwing mower? #4
One local school and the local county fair society both run 15' tri-deck mowers with New Holland TC45D's. If the engine, clutch, and cooling system of your 861 are fully up to snuff, you probably will be OK.
It's a finish mower, not a rotary cutter, correct?
Yes its a finish mower. It is my lawn and pretty much like a golf course so I wouldnt be going over any thick stuff.
Woods 9180, what do you guys think its worth?
   / Ford 861 pull a 15' batwing mower? #6
Worse comes to worse, you can drop off one of the wings and hang a couple hundred pounds of counterweight on the transport wheel opposite the remaining deck.
   / Ford 861 pull a 15' batwing mower? #7
i musta missed somewhere that it was a finishmower.
I was thinking full on batwing. ;)
lol Ok technically they are a "All Flex Mower" but also some refer to them as a batwing finish mower. Still think the 861 would pull it?
With the photos above what would you guys think its worth? new they are around 15K.
   / Ford 861 pull a 15' batwing mower? #10
That I would pay to see, my friend.
I have moved my batwing with my 4600, and I have even powered her up and knocked down bahia blacktops in my hose pasture using my 5000.. I'd have to think my JD 1517 batwing would eat my 800/801/4000 4 cyls lunch though. Actually I think it would eat the clutches lunch.. :)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
John Deere 772-A Grader (A52384)
John Deere 772-A...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
