Ford 861 Carb problem
   / Ford 861 Carb problem #1
wally861
Ford 861
Just put new muffler and manifold on my 861, along with a carburator kit. Have issues now with it stalling out when increasing the throttle. Have done all adjustments that I can think of. Took the pipe off from the air breather to the carburator and gas poured out. Float appears to be adjusted correctly and does not appear to be leaking. Any help would be appreciated.
   / Ford 861 Carb problem #2
sounds like high speed jet is either pluged are not adjusted correctly
   / Ford 861 Carb problem #3
Most likely your float is not adjusted properly or is hanging up. If the float pivot is worn, the floats can rub on the fuel bowl. Give the carb a hard rap with a block of wood and see if it stops overfflowing. if that doesn't work you'll have to readjust the float. Jet adjustments can only be properly made if the float level is correct.
   / Ford 861 Carb problem #4
stalling out as you move the throttle up.
could be flooding or too lean. if lean it will pop and sputter, and a bit of choke will 'fix' it for the test. on the other hand.. choke won't help the flood.. so there's your go/no go test.
soundguy
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
John Deere Van Brunt Grain Drill (A50515)
John Deere Van...
