Ford 850 diesel engine swap?
   / Ford 850 diesel engine swap? #1
mf135, ford 850, farmall H
Trying to see if anyone has knowledge on a diesel engine that would fit(bolt right up or adapter) to a ford 850? I know alot of old tractors had diesel gas or lp versions but dont think the fird 850 did but also know there are some of those "well if you take this engine and do this or that it'll fit"
   / Ford 850 diesel engine swap? #2
A Ford 4 cylinder diesel 144 cu. in. engine was introduced in 1958 and used in the 601 and 701 series of tractors. The 4 cylinder diesel 172 cu. in. engine was introduced at the same time and was fitted to 801 and 901 series Fords. Either would be a direct bolt up for you.
Awesome, thank you for the information. So nice to have access to valuable replies
   / Ford 850 diesel engine swap? #4
I dont think I have ever seen any tractors of that body style that wernt gas.
   / Ford 850 diesel engine swap? #5
Ive never seen a gas one. 601 and 801 close to me are diesel. My Fordson is diesel.
   / Ford 850 diesel engine swap? #6
From what I remember when researching a replacement engine for my 961, the 4 cylinder engines from the 800 and 900 cannot be replaced by the newer 3 cylinder 3000 and 4000 engines.
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
