strum456
Platinum Member
I have been fighting with this for longer than I'd like to admit. I have a nice 841 with PS and a Sherman over/under. BUT, the tractor is almost unusable because you never know when the carburetor is going to start acting up.
For example, tonight we ran the mower conditioner for an hour and a half with no problems. With only a few rounds left, it shut off. It started right back up, mowed for a minute and then shut off. We repeated this process about 10 times before getting another tractor.
What has been done so far:
1. Checked fuel cap - not an issue. Problem occurs with no cap
2. Checked fuel flow to the carburetor - there is plenty.
3. Vapor locking - I re-routed the fuel line towards the front of the engine and down to the carb. to keep it away from the manifold heat.
4. Checked float height and verified no contact with float bowl. I wiped grease on the inside of the bowl and rattled the float around to see if any grease rubbed off.
5. Replaced float valve needle and seat.
The only thing I can think of is the float is hanging up, but I have checked everything many, many times. I cannot find any reason why the float would be sticking. I have noticed that the more gas you have in the tank, the less of a problem this is. I had a 1/2 tank when it started shutting off tonight.
