ford 8210 lift problem
   / ford 8210 lift problem #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
I'm looking at buying a 8210, but the lift doesn't work. it doesn't go up or down. the pto and everything works on it. it is a mid 80s maybe early 90s ford 8210 4wd with a cab. the man said it had all been rebuilt with new hydro pump. does anyone know what the problem maybe be before i jump into this purchase? thanks!
   / ford 8210 lift problem #2
Does it have electrolink or just or just regular lever .
i am not sure if it is normal or electro how much of a problem could it be
   / ford 8210 lift problem #4
Hey, im guessing link arms raised slightly when you say lift will neither raise or lower!?! If so may be as simple as ASC valve being pulled out thus diverting oil to aux services rendering lift "dead". Pushing in valve should reactivate lift function.
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
LINDE H70 FORKLIFT (A50854)
LINDE H70 FORKLIFT...
