Ford 801 Hydraulic blues
   / Ford 801 Hydraulic blues #1
texczech51
weimar tx
cx105
This 801 lift does not work at all... Have substituted a working pump, rebuilt the cover, adjusted linkage- absolutely nothing. Fluid comes out of the pump plug when running.If the pump is removed and air is put into the discharge port with a rubber tipped blower the lift arms will lift. I am wondering if there is a suction screen in the system? If so let me know. Or, any other ideas? Thanks!
   / Ford 801 Hydraulic blues #2
There is no screen in the system, I would suggest you check out the relief valve. It is located under a plate on the bottom of the hydraulic housing.
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
CHEMICAL STORAGE CONTAINMENT TANK (A50854)
CHEMICAL STORAGE...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
