Ford 801 diesel tractor
   / Ford 801 diesel tractor #1
gshiffle
Dyke Va
Ford 801 diesel
Hello,
My name is George and I am new to the forum.
I have a Ford 801 diesel tractor. runs and starts great, hot or cold. Maintains good oil pressure (hot and cold) problem is, when it gets hot, especially when brush hogging at higher rpms, it leaks oil from the breather on the side of the valve cover. I do not notice any lost of power, brush hogs great. Could this be blow-by? any ideas?
Thanks for your help,
George
   / Ford 801 diesel tractor #2
Welcome to the Site. It has been years since I had one of those 4 cylinder diesel's as I recall mine did the same thing it wasn't a lot just enough to make a small mess. I figured it was blow by and not having any type of recirculating system for the pressure build up was causing it. If you can get a hold of Soundguy here on the Forum I am sure he has the low down on the problem.
Thank you for your reply. You are correct, not a lot but does make a mess. Any idea how I can get in touch with Soundguy?
Thank you for your help
   / Ford 801 diesel tractor #4
I see most of Soundguy's post in the Ford Vintage Section. I would look him up and maybe send a pm to him to see what his experience as been .
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
