Ford 8000 PTO shaft/seal question
   / Ford 8000 PTO shaft/seal question #1
ford8000tractor
columbus,indiana
Ford 8000
I have a ford 8000 tractor and I am needing some help. I have an oil leak coming from the shaft and I suspected the shaft seal, but after I just went out and checked again, I can pull the shaft back and forth in the housing. Now, correct me if I am wrong, but shouldn't this be snug and not be going in and out?
Also, if I turn the pto shaft, everything turns including the seal.
Here is the youtube video of it. Any help is appreciated.
IMG 8649 - YouTube
Update: I removed the 4 bolts and took off the bearing retainer and seal. the seal that is in it is brand new and for some reason this seal "turns". the seal Part#9822345 . Also the shaft play back and forth I have not figured out as the bearing looks good and see no other obvious issues.
2011 Isuzu NPR 16ft Box Truck (A50323)
2011 Isuzu NPR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
