Ford 8000 PTO shaft/seal question
   / Ford 8000 PTO shaft/seal question #1
ford8000tractor
columbus,indiana
Ford 8000
I have a ford 8000 tractor and I am needing some help. I have an oil leak coming from the shaft and I suspected the shaft seal, but after I just went out and checked again, I can pull the shaft back and forth in the housing. Now, correct me if I am wrong, but shouldn't this be snug and not be going in and out?
Also, if I turn the pto shaft, everything turns including the seal.
Here is the youtube video of it. Any help is appreciated.
IMG 8649 - YouTube
Update: I removed the 4 bolts and took off the bearing retainer and seal. the seal that is in it is brand new and for some reason this seal "turns". the seal Part#9822345 . Also the shaft play back and forth I have not figured out as the bearing looks good and see no other obvious issues.
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
Honda EM7000iS 7000 Watt Inverter Generator (A50322)
Honda EM7000iS...
Calibre Pump (A50121)
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2005 Woodchuck Chipper (NOT RUNNING) (A50774)
2005 Woodchuck...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
