Ford 8000 differential lock won't release.
   / Ford 8000 differential lock won't release. #1
RCCB
Central Kansas
Ford 8000, MF 1085, IH T-340
I have a 1972 Ford 8000 and it acts like the differential won't disengage. The tractor is very hard to steer and it I try to use the brakes to help steer, it kills the tractor. It was low on hyd fluid, but after I refilled it that did not solve the problem. The PTO and 3 pt both work. Any help is appreciated.
   / Ford 8000 differential lock won't release. #2
It runs on the low pressure pump same as pto clutch. Get the hydraulics hot and see what it does.
I let it idle for 1.5 hours and it did not seem to help. Also, mowed for 4 hours with it and that did not help. I have noticed that the diff lock pedal will not stay up. I tried to hold it up with a block wood, but that has no effect. I disconnected the pedal and the rod that goes into the hyd pump just will drop as soon as you pull it up. Anybody have any ideas?
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
Kubota BX25D (A53317)
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
