Ford 8000 differential lock won't release.
   / Ford 8000 differential lock won't release. #1
RCCB
Central Kansas
Ford 8000, MF 1085, IH T-340
I have a 1972 Ford 8000 and it acts like the differential won't disengage. The tractor is very hard to steer and it I try to use the brakes to help steer, it kills the tractor. It was low on hyd fluid, but after I refilled it that did not solve the problem. The PTO and 3 pt both work. Any help is appreciated.
   / Ford 8000 differential lock won't release. #2
It runs on the low pressure pump same as pto clutch. Get the hydraulics hot and see what it does.
I let it idle for 1.5 hours and it did not seem to help. Also, mowed for 4 hours with it and that did not help. I have noticed that the diff lock pedal will not stay up. I tried to hold it up with a block wood, but that has no effect. I disconnected the pedal and the rod that goes into the hyd pump just will drop as soon as you pull it up. Anybody have any ideas?
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Case SV250 (A50490)
Case SV250 (A50490)
Equipment Questions (A47164)
Equipment...
(1) HD 20ft Free Standing Corral Panel (A48837)
(1) HD 20ft Free...
74in FEL HD Round Back Bucket (A50397)
74in FEL HD Round...
UNUSED LANDHONOR DDSL FUEL TRANSFER PUMP (A50460)
UNUSED LANDHONOR...
