Ford 800, Which Carb??
   / Ford 800, Which Carb?? #12
Will do.
Just found this pdf and found the 593 is for an 800 and the 765 is for a 600. So I have been running on a carb for a smaller engine.
http://www.tomco-inc.com/Catalog/agricutural&indust.pdf
A lot of other information there as well.
Yup.. I knew 593 was for the larger engine models.
By the way.. you CAN make the 765 work, you just have to enrich it a bit.
I'm running a farmerized NAA carb on my 950 i mow with.. because it was available and cheap. tsx 428 i think... ;)
Cool deal, wonder if I would need to drill out any of the jets a tad? I had just felt that I didnt have enough adjustment. I will check again to be sure. I had read extensively about the lean miss condition some of these carburetors have, and some had drilled out the jet(s) to correct it. Although, my problem is probably not that complicated.
   / Ford 800, Which Carb?? #14
I have before..
Looking back through both carbs, I found the original main mixture adjustment and idle mix adjustment screws to be larger on the 593 vs the 765. All other jets are the same size, except the 765 is missing the economizer jet. So that circuit shouldnt be functioning while the tractor is running because there is no orifice to create a pressure drop. The 593 does not have this circuit at all.
What I planned to do was to swap the adjustment screws from the 593 and put in the 765 to see how much difference they make.
The adjustment needles are ~.020" bigger than the 765.
Just an update on my findings for future searchers...
I have finally moved away from tinkering with the carb. I have been adjusting and adjusting and adjusting trying to eliminate the lean-miss sounding sporadic put-put sound. From what I have found, these carbs are extremely forgiving. The 765 is still on my tractor and it is running.
My issues were not fuel related in the first place.
For giggles, I checked to see if the exhaust was actually blowing out the of tail pipe, or if it was sucking in whenever it would make the pffft sound.
It was actually sucking in, so the issue was not fuel related. I didn't want to get into a valve job just yet so I decided to try some snake oil remedies first, because this tractor does not get used unless I go on a romp or snow removal. I tried some water first. Brought the engine up to temp and set RPMs to ~1800. Removed the plug above the carb on the manifold and started adding a little bit of water at a time. I ran about 8oz of water through her and on my last little bit of water, I let it get sucked in and then shut down the engine. Replaced the plug in the manifold and let the tractor sit and steam for about 3mins. Cranked it back up, and no change...still sucking in through the tail pipe.
Went back to my shelf of tricks and got some ATF, did the same procedure. After cranking it back up, it wasn't sucking anymore but was very occasional. Did the same process again with ATF and now its sounding smooth. I knew the intake valves were horridly carbonized, but figured they were seating as I was getting fairly good compression readings, and the wet test proved that the piston rings were worn.
   / Ford 800, Which Carb?? #17
stuck valves on these, while not wildly common.. are VERY possible.
I have had a couple with stuck open intakes. One stuck so bad it bent all my Intake pushrods.
put some atf in the oil and a heavy dose inthe gas and run her.
sure. some smoke.. but ok top end lube.
If it keeps happening, change the oil, and buy cheap store brand ( walmart or kendal is cheapest ) 10w30 full synthetic oil and run her with that.
I have 2 tractors I am running on full syn oil after having stuck valves ( after I did head work ), and they are purring like a kitten.
   / Ford 800, Which Carb?? #18
forgot to mention.. it is always possible you have a bad valve spring too.. that takes a little more work to check... so if the atf or syn oil don't help.. you just might have abad spring.
Thanks soundguy, I will give that a try. New problem starting with the tractor now is it doesn't respond well with load changes. Even letting out on the clutch has to be very gradual or it will stall. Even a small change in incline of ground will cause it to stumble. It will only recrank if you jack the throttle lever back and forth. I'm thinking I may have dusted off some cobwebs that were holding something together, as I have been pulling up some crape myrtles last couple of days and doing some ground leveling. Funny how these old irons have such a sense of humor.
   / Ford 800, Which Carb?? #20
check to make sure nothing is jambing the governor rod and linkage to the carb. ( left front of the engine. )
something may be bent / binding.. maybee a branch stuck in there..... etc. seen that before..
2014 Ranger 900 XP EPS Browning Edition  (A47371)
2014 Ranger 900 XP...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
2010 John Deere 2305 4WD Tractor (A49251)
2010 John Deere...
PALLET OF HOSE REELS WITH GUAGES (A48992)
PALLET OF HOSE...
2014 TROXELL 130BBL VACUUM TRAILER (A48992)
2014 TROXELL...
2014 CHEVROLET SILVERADO 1500 (A48992)
2014 CHEVROLET...
