Ford 770 loader on a ford 1300 tractor
   / Ford 770 loader on a ford 1300 tractor #1
jcurrin
My boss just picked up a ford 1300 tractor with a 770 loader. None of the hydraulic hoses are attached. I have not got a clue where the lines go to the cylinders and the spool valves and the inlet/outlet, any and all help would be appreciated so I can keep working? Thanks
John
   / Ford 770 loader on a ford 1300 tractor #2
Thought I had an old schematic but can't find it.... I think I can describe it to you. There should be 7 hook ups on the bottom of the valve. The 3 that run in a row are for your hydraulic lines from pump etc.The other 4 hook ups are for the loader cylinders, to hook those up looking down from the top( joystick side) of the valve:
Front right is for loader "drop"
front left is for loader "lift"
Back right is for bucket "curl"
Back left is for bucket "dump"
The 3 ports in a row should be marked with the letters N, P and T cast into the body of the valve...these stand for:
T = Tank port (return going back to the sump)
P = Pressure inlet from the pump
N = power beyond outlet to the Next valve
Your hydraulic line from the pump will hook up to the middle "P" port.
The "N' port will run on back to the 3 point hitch
The "T" port will dump back into your transmission
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2023 EXA INDUSTRIAL EXA INDUSTRIAL (A52472)
2023 EXA...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
