Ford 770 loader on a ford 1300 tractor
   / Ford 770 loader on a ford 1300 tractor #1
jcurrin
My boss just picked up a ford 1300 tractor with a 770 loader. None of the hydraulic hoses are attached. I have not got a clue where the lines go to the cylinders and the spool valves and the inlet/outlet, any and all help would be appreciated so I can keep working? Thanks
John
   / Ford 770 loader on a ford 1300 tractor #2
Thought I had an old schematic but can't find it.... I think I can describe it to you. There should be 7 hook ups on the bottom of the valve. The 3 that run in a row are for your hydraulic lines from pump etc.The other 4 hook ups are for the loader cylinders, to hook those up looking down from the top( joystick side) of the valve:
Front right is for loader "drop"
front left is for loader "lift"
Back right is for bucket "curl"
Back left is for bucket "dump"
The 3 ports in a row should be marked with the letters N, P and T cast into the body of the valve...these stand for:
T = Tank port (return going back to the sump)
P = Pressure inlet from the pump
N = power beyond outlet to the Next valve
Your hydraulic line from the pump will hook up to the middle "P" port.
The "N' port will run on back to the 3 point hitch
The "T" port will dump back into your transmission
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
