Ford 7600 hydraulic problems
/ Ford 7600 hydraulic problems #1
Rmoreland71
Ford 3000, Ford 4000, Ford 5600, Kubota 2650
I have a ford 7600 that I recently purchased. When i first got it, i was cutting some hay with a 489 NH haybine. After about 2-3, the hydraulics would get weak, and the PTO would stop working. After id sat overnight everything would work normal again for a few hours then the same thing. I used very little for a while thinking the pump was going out. I used for about 45 minutes, and lost all hydraulics. I pulled a pump from a 5600 that my dad had had sitting for a few years with a bad motor, and the same thing no pressure. Is there something else that could be causing the issue? Is there a screen on the pick up tube for the pump? If so how do you get to it to check?
When cutting hay it was 2-3 hours.
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
7000bu Grain Bin (A66408)
7000bu Grain Bin...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2001 Peterbilt 378 T/A Wet Kit Day Cab Truck Tractor (A64194)
2001 Peterbilt 378...
