Ford 7600 hydraulic problems
   / Ford 7600 hydraulic problems #1
Rmoreland71
Ford 3000, Ford 4000, Ford 5600, Kubota 2650
I have a ford 7600 that I recently purchased. When i first got it, i was cutting some hay with a 489 NH haybine. After about 2-3, the hydraulics would get weak, and the PTO would stop working. After id sat overnight everything would work normal again for a few hours then the same thing. I used very little for a while thinking the pump was going out. I used for about 45 minutes, and lost all hydraulics. I pulled a pump from a 5600 that my dad had had sitting for a few years with a bad motor, and the same thing no pressure. Is there something else that could be causing the issue? Is there a screen on the pick up tube for the pump? If so how do you get to it to check?
When cutting hay it was 2-3 hours.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
