Loader Ford 7108 Build Date/Serial Number
/ Ford 7108 Build Date/Serial Number #1
johnny1720
Allegany, NY
Ford 1720
I recently purchased a 7108 loader. The decal says Ford. The metal plate says New Holland 7108 Serial # YL875118.
Just curious what year loader this is, I want to get a owners manual.
Thanks
/ Ford 7108 Build Date/Serial Number #2
I want to say the year is the first digit of the serial number, but not sure. There is only one manual available though: 43591002
/ Ford 7108 Build Date/Serial Number #3
Scanned a few ppg (specs, troubleshooting) from my NH 43591002 (9/96) to .pdf. (vs blotchy .jpg)
Turned out well, clear. Print nice on my Brother B&W laser, no blobs, blushes, voids ...
How to send .pdfs to OP? (Can do whole book, easy ...) tog
/ Ford 7108 Build Date/Serial Number #4
Probably right around the switchover year, about 1994? Not sure if I have that right but mine is a 1993 and it's all labelled Ford.
Jim
/ Ford 7108 Build Date/Serial Number #5
If it really is a Ford, the first two characters (alpha) was an internal supplier ID. If they are not both alpha then they are NH and their system.
/ Ford 7108 Build Date/Serial Number #7
The 7108 never was a factory match for any New Holland branded tractor with the exception of a very few late 20 series tractors that carried the NH decals. The 7308 replaced the 7108 and was designed for the 1925, 1630 and other original Boomer models. They also fit (more or less) the 20 series models that the 7108 was designed for. A 7308 with original style mounts on a 1920 with R-1 tires would barely put the bucket flat on the ground and would not at all dig below grade with the bucket flat. Then the front mount was redesigned a little to fix that problem. I always thought a 7108 was more robust then the 7308. SMC built both models for CNH.
/ Ford 7108 Build Date/Serial Number #8
That's what I read in Tractordata. They claim the Ford 1720, NH 1920, and NH 1520 all used the 7108 loader.
/ Ford 7108 Build Date/Serial Number #10
I'm pretty sure my Ford 1720 is supposed to have the 7108, but it has a 770b instead.
I will pm you my email address. Thank you thank you.
/ Ford 7108 Build Date/Serial Number #13
Email sent. ;)
Thanks for the input people,
Now that I have a loader I can start straightening up some of my property.
/ Ford 7108 Build Date/Serial Number #16
Big chance, the way I see it. :) PM sent.
johnny1720, .. got your PM, .. you're very welcome, .. glad I could help.
t o g (jon)
/ Ford 7108 Build Date/Serial Number #17
t o g (jon)
You think it would be possible to get a copy of that loader manual? Just purchased a 96 model Ford 1720 with that loader and bought a manual for the tractor but haven't had a lot of luck on a decent copy of one for the loader.
/ Ford 7108 Build Date/Serial Number #18
Since this thread is almost a year old, try sending a PM with your email address to the 2 guys he helped out (skills4lou and johnny1720) as well as Mr old grind himself. Maybe one of them has the original PDF and won't have to re-scan.
/ Ford 7108 Build Date/Serial Number #19
I'll see if I can figure out the message thing. This is the first forum I've ever participated in. Thanks for the advice!
/ Ford 7108 Build Date/Serial Number #20
uploading it to gmail right now, should have it in an email soon. Happy to help out!
Welcome to the forum. :)
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2020 DRAGON ESP...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
2003 International 9200I (A53317)
2003 International...
1986 KUBOTA R-400 WHEEL LOADER (A60429)
1986 KUBOTA R-400...
