carlbman
- Joined
- Dec 3, 2014
- Messages
- 6
- Location
- Leslie, MO
- Tractor
- Bobcat 753, John Deere 970 with Loader and Back Hoe, AC 200, AC WD45, Ford 4500 Back Hoe
I recently bought a 1980 Ford 6700 MFWD. The seller did indicate that the clutch was weak. It did not slip when I test drove it around his place. When I got it home and tried it out, I found that the clutch would slip when driving it on a road in high gear with a slight incline. I am guessing that I am in need of a clutch change, but before I get too deep, I wanted to check and see if there was a possibility that the hydraulic part of the drive train might be weak and causing the slippage. The low/high hydraulics (not sure what it is called, I have a couple of manuals on the way) shifts good and possitive when shifting in lower gears. The slippage is still there when shifting the hydraulic low/high. I have a Allis-Chalmers 200 that was slipping on the low/high hydraulics, acting the same way and an adjustement took care of that. The tractor shows indications that it had a loader in a previous life. Thanks for the help.
Carl
Carl
