Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged.
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #1
TomSam
Tampa
Kubota 5800
I looked up the trouble shooting in the PDF service manual. It seems it is more complex than I would have thought it was. The tractor had been sitting for sometime before I brought it back to life. I told the owner to hook his bush hogg to it and just run it and see if it frees itself up. I know that is probably a dream but what the heck let's try. Has anyone dealt with this before that can offer any insight on the best way to Diagnose exactly what is wrong, and fix it the easiest way? Thanks
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #2
The PTO brake is worn out probably from shutting the PTO off at mid or full speed
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #3
Was the bush hog still connected? Did you try putting and load on bush hog like cutting grass to see if it stopped?
Like tractor tech I also suspect worn brake band but a small load should stop the PTO if it disengaged properly.
We had 5610 and I do not remember anymore if there are any adjustments on that Band. I do believe was accessible by removing rock shaft cover for visual inspection.
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #4
There is some adjustment on it, but typically it is worn too far. Access is through the rock shaft/topcover.
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #5
I agree, clutch pack is shot and if it's like my Kubota's major surgery will have to take place to fix it. Why I always run an over running clutch on my PTO stubs of I'm running an implement that don't have one built in. Choppers and shredders are all very guilty of it.
Inertia driving the PTO after it's disengaged will quickly screw the pto clutch plates and then the PTO won't stop turning.
Have fun and it won't be cheap to repair.
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #6
Nice 5 gallon finish lol Where is the rest of the hood?
Do I access that from the top or the rear....wow that sounds bad...lol
I tried to stop it by wedging a 2x4 up against the shaft to see if it had force behind it.It just ground a big notch in it. The owner is going to hook a bush hog on it and see if it running it a little will help
   / Ford 6610 PTO will not shut off. It just slows down a little bit when disengaged. #10
The 3pt topcover under the seat comes off. Access is great once it is off
It may be possible to access the adjustment and/or have a look at it from the LH access plate (round plate on the side of rear axle).
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
2020 KUBOTA RTV...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
Non running toro mower (A48082)
Non running toro...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
