ford 6610 4.4L industrial engine timing(HELP)
   / ford 6610 4.4L industrial engine timing(HELP) #1
rwe3
sylvania,ga
ford 6610
I need a timing diagram for this engine. I have completly rebuilt engine and not sure about pump timing.
   / ford 6610 4.4L industrial engine timing(HELP) #2
which pump do you have if you have the timing cover removed just line up all the dots on the gears but has far has to time the pump will need to know what model 6610 and what pump you have
I have valve timing set by the marks on cam,crank, idler gears. I removed #1 injector and rotated engine with ratchet. #1 injector squirted on exhaust stroke. This engine is actually in a 1986 rough terrain lift. It is same as a 6610 ford engine. It has a minimec pump
   / ford 6610 4.4L industrial engine timing(HELP) #4
I thnk your cam is off 1/2 a turn. Try rotating the crank one turn than line up all the timing marks again. Be sure to slack off the valves so they do not hit pistons when you turn the cam to reset all the timing marks.
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
