ford 6610 4.4L industrial engine timing(HELP)
   / ford 6610 4.4L industrial engine timing(HELP) #1
rwe3
sylvania,ga
ford 6610
I need a timing diagram for this engine. I have completly rebuilt engine and not sure about pump timing.
   / ford 6610 4.4L industrial engine timing(HELP) #2
which pump do you have if you have the timing cover removed just line up all the dots on the gears but has far has to time the pump will need to know what model 6610 and what pump you have
I have valve timing set by the marks on cam,crank, idler gears. I removed #1 injector and rotated engine with ratchet. #1 injector squirted on exhaust stroke. This engine is actually in a 1986 rough terrain lift. It is same as a 6610 ford engine. It has a minimec pump
   / ford 6610 4.4L industrial engine timing(HELP) #4
I thnk your cam is off 1/2 a turn. Try rotating the crank one turn than line up all the timing marks again. Be sure to slack off the valves so they do not hit pistons when you turn the cam to reset all the timing marks.
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2005 TerraGator 8104 (A52128)
2005 TerraGator...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
