Ford 6600-DUAL POWER
   / Ford 6600-DUAL POWER #1
401FordManNZ
New Zealand
Fords
Hi there,well I was going about in the tractor graveyard looking for a Dry element aircleaner,when I stumbled across a 6600 dual power transmission(much to other halfs dismay!),Price is reasonable and I could use the underdrive while mowing paddocks for silage,question is:
My hydraulic pump has a bung where the the dual power line tees off pump,can I use my pump or will this overtax the PTO circuit?
Also with the dual power linkage, there seemed to be no solenoid or linkage there,how could I go about engaging dual power? Would it be best to fabricate a handle or footswitch to activate it?
From the letters on the transmission it seemed to be a 1979 model 6600 equiped with load monitor, would this mean I don't need a sprung centre clutch plate for the tractor to be smooth? I'm already thinking of going to a 13'' plate now as 12'' and 100hp might be a mismatch!!
Many thanks to you and have a great easter break....:confused2:
   / Ford 6600-DUAL POWER #2
if it had a load moniter it is out of the 7600 fords and they had a handle out the side of the cowlin that worked the dual power and the cab tractors had a foot pedal but u need to make sure the little filter in the side of the dual power it is best to change it while the trans is out so u can get to it easy they are bad about cloging up if they get a little bit of trash in them and cause about 4000 dollars worth of damage
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
2015 Ford Expedition EL SUV (A51694)
2015 Ford...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
