Ford 655D vs 675D backhoe?
   / Ford 655D vs 675D backhoe? #1
jfh0jfh
EC Ohio
Kubota MX5100, JD 710, Case 450
I'd looked at some 655s and just recently came across 2 675s. Same size and years as the 655 (I think). I assume the 675 is a 655 with more HP (the owners don't seem to know).
There's also a 575 but I haven't run one yet.
Anyone know the difference between these 2 machines? Or where I might find specs? I couldn't find anything online eqivalent to the older_backhoe_specs that John Deere maintains on its website.
Builder said:
Those are probably 10 ton backhoes.
It could be that the 655 is N/A and the 675 is turbo, but that's just a wild guess.
655/ 675 are ~ 8-8.5 tons per Ford dealer. I guessed that the n75 would be a turbo but there are 655 Turbos so that didn't work either.
   / Ford 655D vs 675D backhoe? #4
Is it a 655/675 Cab & 4x4? Cab & 4x4 adds a lot of weight.
No heavier than a 580 SuperM. I'm ~17,500 lbs.
Yes, all machines I've looked at recently are cab, 4x4, extendahoe.
Are you 17K? I didn't realizea 580 was that heavy.
A 480 should be equivalent to a JD 410. A 410C is 14,000 lbs + 4x4 + extendahoe + cab. So ~16,500 - 17,500 is more a JD 510 weight. A 510D is only ~18,000 loaded up. That's made to match the 590.
I think the dealer said ~ 16,500 on the 655. Maybe he was thinking of an OROPS and or 2WD, who knows?
I was thinking of hauling a 580SL (or this 655) home behind a friend's 1-ton. I was probably thinking 15,000 on the weight and I thought that was on the edge. If it's really 17,000 that's too much.
   / Ford 655D vs 675D backhoe? #6
yep. 17,400 lbs. lookie here-scroll down to bottom:
CASE | North America / English | Products | Loader/Backhoes | 580 Super M Series 2
Builder said:
Much heavier than I thought and yes, you're spot on. Some other machine weights below fyi. (There's a 590M 4WD cab 4x4 advertised as 14,000 weight on ebay right now. Followup: I emailed him and he replied that 14,50 is what the machine weighs).
I must have been thinking of the base hoe (no cab, no weights, no 4x4, no ext-hoe) even though I had gotten the numbers for those and was adding 2500-3000 lbs for those (the JD 510D adds ~ 3200 lbs for them).
from various sources:
580 SM - 14285 (2WD "light"); 17545 "heavy config" (4x4, EROPS, ext-hoe
590 SM - 15268 light; 19578 heavy config (cab 454, weights 440/ 990, ext-hoe 270, 4WD 393
Ford/ NH 555 - 15,500 (cab. 4x4? Ext-hoe?)
JD 510D - 19072 = (16,000 + cab 500 + ext-hoe 1182 + 4WD 190 + counterweights 1200)
JD 410G "18,500-lb typical operating weight".
JD 710G "26,500-lb typical operating weight"
1997 Mercedes Convertible (A48082)
1997 Mercedes...
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
Brent 644 S/N B29830123 (A52128)
Brent 644 S/N...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
