Ford 655D vs 675D backhoe?
   / Ford 655D vs 675D backhoe? #1
jfh0jfh
EC Ohio
Kubota MX5100, JD 710, Case 450
I'd looked at some 655s and just recently came across 2 675s. Same size and years as the 655 (I think). I assume the 675 is a 655 with more HP (the owners don't seem to know).
There's also a 575 but I haven't run one yet.
Anyone know the difference between these 2 machines? Or where I might find specs? I couldn't find anything online eqivalent to the older_backhoe_specs that John Deere maintains on its website.
Builder said:
Those are probably 10 ton backhoes.
It could be that the 655 is N/A and the 675 is turbo, but that's just a wild guess.
655/ 675 are ~ 8-8.5 tons per Ford dealer. I guessed that the n75 would be a turbo but there are 655 Turbos so that didn't work either.
   / Ford 655D vs 675D backhoe? #4
Is it a 655/675 Cab & 4x4? Cab & 4x4 adds a lot of weight.
No heavier than a 580 SuperM. I'm ~17,500 lbs.
Yes, all machines I've looked at recently are cab, 4x4, extendahoe.
Are you 17K? I didn't realizea 580 was that heavy.
A 480 should be equivalent to a JD 410. A 410C is 14,000 lbs + 4x4 + extendahoe + cab. So ~16,500 - 17,500 is more a JD 510 weight. A 510D is only ~18,000 loaded up. That's made to match the 590.
I think the dealer said ~ 16,500 on the 655. Maybe he was thinking of an OROPS and or 2WD, who knows?
I was thinking of hauling a 580SL (or this 655) home behind a friend's 1-ton. I was probably thinking 15,000 on the weight and I thought that was on the edge. If it's really 17,000 that's too much.
   / Ford 655D vs 675D backhoe? #6
yep. 17,400 lbs. lookie here-scroll down to bottom:
CASE | North America / English | Products | Loader/Backhoes | 580 Super M Series 2
Builder said:
Much heavier than I thought and yes, you're spot on. Some other machine weights below fyi. (There's a 590M 4WD cab 4x4 advertised as 14,000 weight on ebay right now. Followup: I emailed him and he replied that 14,50 is what the machine weighs).
I must have been thinking of the base hoe (no cab, no weights, no 4x4, no ext-hoe) even though I had gotten the numbers for those and was adding 2500-3000 lbs for those (the JD 510D adds ~ 3200 lbs for them).
from various sources:
580 SM - 14285 (2WD "light"); 17545 "heavy config" (4x4, EROPS, ext-hoe
590 SM - 15268 light; 19578 heavy config (cab 454, weights 440/ 990, ext-hoe 270, 4WD 393
Ford/ NH 555 - 15,500 (cab. 4x4? Ext-hoe?)
JD 510D - 19072 = (16,000 + cab 500 + ext-hoe 1182 + 4WD 190 + counterweights 1200)
JD 410G "18,500-lb typical operating weight".
JD 710G "26,500-lb typical operating weight"
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
