ford 655c backhoe to 3pt hitch conversion
   / ford 655c backhoe to 3pt hitch conversion #1
forester2009
Hello,
Does anyone know if a ford 655c backhoe can be converted to a 3pt hitch setup? Does the agriculture tractors and the construction side share the same chassis?
   / ford 655c backhoe to 3pt hitch conversion #2
The powertrains are very different from the engine back. Theoretically it could be done, but at great expense. Probably replacing the transmission and rear axle center housing plus adding all the PTO and hydraulic components (lift cover, pump, controls and linkage, & external 3-pt parts).
   / ford 655c backhoe to 3pt hitch conversion #3
A d removing the backhoe components including the valuing. And the operator platform will be in the way........
So essentially, no.
Rock Bucket (A50121)
1994 GMC Top Kick Grain Truck (A50514)
1994 GMC Top Kick...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1273 (A50490)
1273 (A50490)
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2015 Kubota L2501 (A50120)
2015 Kubota L2501...
