Ford 600
   / Ford 600 #1
billyj
Hello folks
I need help identifying the 4 bolt cover plate on the bottom of this transmission.
There is a hole in the center of the of the 4 bolt plate...what you see hanging out of the hole is a piece of metal and not a plastic tube that is appears to be. I discovered this while i was changing engine oil. When i parked the tractor and went underneath to drain the oil i notice the leaking of transmission fluid but it stopped shortly after the shutting off the engine
Your input would be greatly appreciated/
   / Ford 600 #2
Pouring out now, will have a look later this afternoon and grab a pic of what our 641 looks like in that area - but I can tell you I sure don't remember anything looking like that!
   / Ford 600 #3
Would you be accessing the bellhousing area if this plate is removed, also the clutch? Is the tube simply a drain for that compartment?
   / Ford 600 #4
Actually in the bellhousing. Leaking from rear main engine or from input shaft seal. Cotter pin keep the hole from clogging up. Dap a little fluid on your finger. Does it smell like engine oil or gear/hydraulic oil. Or you can watch the fluid levels on your engine oil and tranny and see which one goes lower.. A tractor split might be required to fix.
Kirk
   / Ford 600 #5
Finally stopped raining long enough to peel the tarp off and run the old girl up and down the road a bit. Here's my pics from today, same as yours, 'cept no oil leaking.
Click on the pic to make bigger.
   / Ford 600 #6
As Kirk said, bellhousing drain
RHINO SE8A SHREDDER (A52472)
RHINO SE8A...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
