Ford 600 Thermostat
   / Ford 600 Thermostat #1
tderrick
Nashville
L3901 , Ford 8N and 640
Is anyone running their Ford 600's without a thermostat in the summer?
   / Ford 600 Thermostat #2
Just dealth with this issue on my 640 which was running cool.
Found that the orginal thermostat was not completely closing, stuck partially open below 160 deg F.
All the information (shop manual and tractor archives) I came across recommended that a 160 deg themostat be installing for the 600 model gas engine, including summer operation.
Installed a NAPA model 70 thermostat after drilling a small weep hole to match the original. Tractor now warms up to operating temperature after a few minutes of cranking.
Hope this helps. Search the archive here and at Yesterdays Tractor.
   / Ford 600 Thermostat #3
ford designed it to use a thermostat... he wasn't into putting wastefull parts in his tractors... run a thermostat... or if you overheat.. revamp the cooling syste,.. ie.. pump and radiator... no need to reinvent the wheel here...
soundguy
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
Hose Reel (A53424)
Hose Reel (A53424)
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
