Ford 600-Engine vs PTO speeds
   / Ford 600-Engine vs PTO speeds #1
downslope
Platinum Member
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
On 600 series what speed is the PTO turning when the engine is at 1000 rpm? This is 4-speed trans, non-live, gas motor. Ford 2000 with 4-cyl gas motor would also be the same, is that right?
   / Ford 600-Engine vs PTO speeds #2
I can't tell you exactly but most older Ford tractors are at 540 pto speed around 80% throttle or about 1750 rpms on an engine governed at 2200 rpms.
Extrapolating from that, 1000 rpm would give you a pto speed of about 325 rpm.
These are rough numbers of course.
Yes, a 4 cyl 2000 with a 4 speed would be the same as they are almost identical tractors.
Any of the 4 and 5 speeds - with or w/o lpto would likely be about the same.
   / Ford 600-Engine vs PTO speeds #3
I think UD is pretty much spot on. looking at a pic of a proofmeter on one of my 5 speeds.. it does look darn close to 1750 for pto speed. which may sometimes be listed as 538 even. for the 540 'standard'
   / Ford 600-Engine vs PTO speeds #4
I agree. We called 1800 RPM 540 PTO RPM for years.
Thank you all. I had a feeling it was around 1750 for 540pto but wanted to double check. I will be moving a sprayer I previously used on the Fords to a different tractor and wanted to choose a gear that would give about the same pto speed at 3 mph.
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
Guard Rail Joints (A51692)
Guard Rail Joints...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
