Ford 575D backhoe hydraulics question
   / Ford 575D backhoe hydraulics question #1
rfarm1947
Frod 575D Backhoe
I recently picked up a Frod 575D backhoe. I am looking into the possiblity of attaching an Erskine Model 2418 snowblower in place of the front bucket for winter use. The snowblower requires 27-32 GPM flow. Question - is this a feasible project? And, will it require a seperate pump and reservoir?
Thanks for your help
   / Ford 575D backhoe hydraulics question #2
   / Ford 575D backhoe hydraulics question #3
At 30 gpm, and a fairly large cooler, your 575D will hydraulicaly be able to handle the snowblower.
You'll need to run the proper size hoses up the loader arms, and install a diverter valve in the system, in between the loader and BH valves.
Thanks for your responses. I am still debating whether this project is feasible. One problem is where to mount a reservoir on the backhoe, or would the primary reseroir of the backhoe hydraulic systme work.
   / Ford 575D backhoe hydraulics question #5
It is feasible, the hardest part is running the hoses up to the loader arms.
The original reservoir will be sufficient.
Once again, thanks fior the help. This is the information I have been looking for. Now that it is warming up a bit, and the snow is melting, I hope to get started on this project and be ready for next winter. Will keep you informed.
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
Husqvarna YTH 18542 Riding Mower (A53117)
Husqvarna YTH...
2012 International Vactor Sewer Truck (A52377)
2012 International...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
Case 1280 Tractor (A53117)
Case 1280 Tractor...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
