Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #1
Lykins Farm
Shelbyville, KY
1995 New Holland 5610S
I have a Ford 5610S. Just changed the five O-rings under the unload valve on top of the Hydraulic Lift Cover. Very easy and simple job. However, when I got things back together and tightened down, there is a squealing sound coming from the rear 3-point hydraulic when lifting. I think there is more than likely air in the system, but I have no idea where to start on bleeding the air out of that is the issue.
It did not make this squealing sound prior to replacing the O-rings under the unload valve. I tried to attach video but it won't allow me. If you want to hear it, message me your email and I'll forward it
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #3
Video asking for permission. I checked viewer, but nothing happens
I gave permission to a Ted Johnson. If that wasn't you, can you request permission and I can go to email and give the okay. Not sure why it is asking permission.
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #6
Is the sound coming from the unload valve?
1000011568.mp4
This video should work guys. Sorry I am not good with uploading videos.
2008 Geringhoff NS800 8R30 Corn Head (A53485)
2008 Geringhoff...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
(4) PALLETS OF HEATERS (A55745)
(4) PALLETS OF...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
