Oil & Fuel Ford 5600
/ Ford 5600 #1
Elsson
Sweden
Ford 5600,MF35,Volvo T21,T22,T31
Hello all Ford owners.Can someone adwise me what kind of oil i need for mine Ford 5600 from 1976?
Oil for hydralic / gearbox?
Engine?
Power steering?
I also in urgent needs for pepair manual for this tractor.
Best regards Robert.
/ Ford 5600 #2
nh 134 spec oil for the hyd. and gear box
10w40 or 15w40 rotella for motor and powersteering
you can run hyd oil in powersteering also but i run motor oil
/ Ford 5600 #3
New Holland has a great website with all of the info. you are looking for, here is a link New Holland USA - Tractors - Agricultural machinery - Combines, etc.. There website under parts will show the correct oils and filters to use.
If you choose to use a different brand, then you want to make sure that you use the same grade and weights recommended by the manufacturer.
There are shop manuals available through Amazon.com.
/ Ford 5600 #4
15w40 or 5w40 sy inthe engine.. and a utf meeting m2c134d in everything else including PS
soundguy
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
