Ford 555c Back hoe power steering leak
   / Ford 555c Back hoe power steering leak #1
firedude26
bobcart 743
my 555c backhoe has a leak in the power steering system under the cab, i power washed the area today and hoping to find out the best way to access the tubes? i downloaded a manual but it doesnt really say how to access them. i was hoping someone has done this and can fill me in on accessing these?
thanks
Rob
take the center part of hood off, and tank, ok, so once i do that they will be accessable?
Thanks
thanks hopefully more, lol
ok well you was right oull the tank, and take the plate off on the inside, the line coming threw firewall had a hole wore in it in the rubber section. it was the pressurized line, would any one have a part number for that? i havent been to lucky in finding and parts fish to look it up.
thanks
   / Ford 555c Back hoe power steering leak #7
Use the CNH parts website. They have complete parts diagrams for everything on your hoe. Write down the part number and head to your local CNH dealer.
   / Ford 555c Back hoe power steering leak #9
   / Ford 555c Back hoe power steering leak #10
thanks
Rob
The real problem is finding replacements for the tubing that has a section of 3/8 hydraulic hose. They seem to be unavailable. I replaced the hose by crimping new ferrules with an expensive hose crimper after removing the old hose and getting new ferrules It was really hard to do this.
A better way is to get 6 inch hoses made with JIC male fittings. Then get tubing nuts and sleeves and cut old ferrule from each end of the original hose, put nut and then sleeve and then use a 37 degree flare of the tubing on each of the now separate tubes. The steering pressure runs at 1850 PSI so it takes good connections.
The fuel tank has to be removed to access these tubes. The is a cross metal strap that wears through the original hose.
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
