Ford 555 4 by 4 transmission problem.
   / Ford 555 4 by 4 transmission problem. #1
blt987
A branch put a hole in the transmission fillter and I lost all transmission fluid. I shut the tractor down immediately, so I don't think any damage ensued. I installed a new filter and refilled the transmission, but the transmission won't go into either drive or reverse. Being an optimist I am assuming that the problem is air in the pump. Any suggestions for bleeding?. There is nothing in the manuals on the subject.
Bryan.
   / Ford 555 4 by 4 transmission problem. #2
I'm not familiar with that trans, however I did some asking around and so far the consensus is that that trans probably has a TC, and that whatever poked the hole in the filter may have contaminated the system .. like hanging a valve.. etc. Also possible it may have cracked the pump casting and is letting it suck air. (credit Rod at YT for this info ).
Soundguy
Thanks for the reply, Soundguy. I hate to appear as dumb as I am, but what is a TC?, Bryan.
   / Ford 555 4 by 4 transmission problem. #4
Torque converter. ( not a dumb question by the way.)
Soundguy
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
