Ford 550 Starter Assembly
   / Ford 550 Starter Assembly #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I have a 550 that I needed to replace the solenoid on it. I couldn't get the solenoid off, so I pulled it apart and had to remove the solenoid lever pin. I didn't know it was eccentric, but now I do. The service manual has the dis-assembly, but I can't find the assembly section or how to adjust this arm.
Anyone do one of these before? It's a Lucas starter, and probably the same as many 3 cylinder Ford's. Maybe a later version of the service manual for a newer tractor or 555 has it if someone had one to look at?
Thanks,
Well, after typing this, I just remembered I have the IT manual from when I had a 3550. That manual describes how to adjust.
Thanks for the help everyone....
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
2024 KMC 7406 (A53084)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
