ford 5000
   / ford 5000 #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
I'm looking at buying a 1976 Ford 5000.The tractor needs tlc but is in pretty good shape but needs new back tires.The tractor has a snow blower on back a vblade and bucket for the loader out front..I noticed when the guy was showing me the tractor he was moving a lever under the seat to use the front loader or 3ph..I think he was pulling out the lever to operate the valves for loader and pushing in to use the valve for the 3ph.I asked him about that and said thats what he has to do to work them.is there a way to use two at the same time without frigging with that button
   / ford 5000 #2
yes you can buy a hyd. manifoild that bolts under the plate he was messing with and run to hose to the loader valve and then you can use both with out messing with the button
   / ford 5000
where can i buy one and how hard to install
   / ford 5000 #5
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
CFG Industrial QK20R (A50121)
CFG Industrial...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
John Deere 7130 (A50120)
John Deere 7130...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
