FORD 5000 TRANSMISSION PROBLEMS
   / FORD 5000 TRANSMISSION PROBLEMS #1
BRUCED
GRAND PRAIRIE, TX
F0RD 5000
I have a '74 ford 5000 with an 8 forward and 2 reverse transmission. Yesterday I found that I could only shift from 1st to 3rd. The clutch is working but I could not shift to the right...2nd, 4th and reverse. Any suggestion would be appreciated.
   / FORD 5000 TRANSMISSION PROBLEMS #2
The shift rails have become misaligned, you should be able to take the top plate with the shifter loose and lift it off, realign the shift rails and replace the top plate. I'm not familiar with the Ford 5000, but should be an easy fix.
   / FORD 5000 TRANSMISSION PROBLEMS #3
Probably the shift handle or ball is worn allowing handle to slip out of notch in shift fork. As milkman stated just lift cover align forks and re-install cover.
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
